another lift question
thinking of lifting the jeep soon. not sure waht lift is good looking to go 2.5-3 inches. also not sure what other things to consider with the lift. i have read to also use a 3/4 spacer in the front to even out. are there any problems with shaft length using a 2.5 or 3 inch lift. i have a 4 door.
From what I have read here, you will be fine with the 3" lift and stock driveshafts.
