ga ga Gears
Seeking some input from the forum again.
I'm do intend on putting 35s on my jeep and regearing. Would there be any problems with regearing first and using the stock 32s for a while?
thanks... happy turkey day soon!
Do you have an Auto or Manual trans?
what gears are you planning on running 4.88's or 5.13's or what?
You can re-gear now, but you will be a little low, so higher speeds you'll be at higher RPM's.
It would not hurt anything to re-gear first.
mine with 5.13's and an manual is over 3k rpms at 70... but the JK shakes like crazy at around that speed anyway, so I don't drive that fast much.
Have you figured out what the shaking issue is? Mine could do 70-80 and doesn't shake w/auto... can't imagine a manual would make it shake. Do you have a pinion angle problem or other driveline issue?
I think mine is more the tires maybe? mine never seem to be balanced smoothly and my steering is nasty. even stock i had mad play in my steering wheel.
