Disconnecting the sway bar
Please don’t beat me up if this is a stupid question look I am still a Newbie.
Can I disconnect the sway bar on my Sahara easily before I hit the trail and reconnect it just as easily after?
You really need to define easily and even then you're going to run into a mess of opinions. If you don't put a quick disconnect kit in then it's going to be a PITA. You will need to be on totally level ground, you will need two wrenches (I think an 18 and a 19, if memory serves me correctly) and a small rubber mallet doesn't hurt. Take off the nuts at each end of the sway bar links, remove the links, then strap the sway bar up parallel to your frame.
A disconnect kit will cut the time it takes to do all that by at least a quarter and if you get the JKS kit, you won't even have to worry about finding level ground.
Thank you for your help
