Spray in bedliner help
Old Dec 29, 2011 | 06:20 AM
NTX JK's Avatar
Default Spray in bedliner help
So i am spraying in a bedliner today, and I have a few questions. Mainly, is the taping off. Im guessing once I am done spraying, I should pull all of the tapeing off, correct? Or is it better to let it stiffen a bit?
Old Dec 29, 2011 | 06:26 AM
Yamaha90's Avatar
Are you doing your tub?
If it were me, I would wait a few minutes for it to set a little bit, but don't wait too long or the overspray will bond to the tape and rip the edge of the bedliner you laid down. So you can either pull the tape right away, or wait a few minutes. Result may be the same. But i realize you want that defined line. You can always try it first in an inconspicuous area.
Old Dec 29, 2011 | 06:29 AM
sringer's Avatar
My buddy is a professional bedliner guy and he says you have to pull the tape and plastic (or whatever you use to mask) right away.
I am here: http://maps.google.com/maps?ll=48.426713,-114.347060
Sent from my iPhone 4s using Verizon 3G
Old Dec 29, 2011 | 06:38 AM
Wallsofcrete's Avatar
I helped my brother-in-law do his bed rails on his truck and we used a pizza cutter to remove the tape because we put multiple coats on and had to let it dry in-between coats
