Question for 3" JK 2Dr and 2,5" Budget Boost
I want say if i istall on my Jk Rubicon a lift Kit 3" Teraflex I must install also DriveShaft front and rear?
I want say if with the 2,5" Teraflex Budget Boost is possible mount the 35x12.50 r17?
Thanks!
Scuse for my English
I'm Italian
Thanks!
I'm Italian
You guys need to read a little more.
Theres alot of us needing new rear driveshafts for the 2 door and a 3" lift.
The front should be OK for awhile. The rears steep it'll cause your driveline to fail after awhile. You might last 12 months, it might only last 3 months.
My rear failed about 3 or 4 months after the install of my 3" lift..
You would need that If you were lifting a TJ (1997-2006)
Jk's dont require a SYE.
its just the driveshaft and possibly a yoke depending on what you want.
I can't tell from your pictures, but are your driveshafts the heavy duty 1350. or 1310? How much lift will the 1350 be usable on? Can I put on 1350 with a 2-3 inch lift and then upgrade to 4 inch later? What about 6 inch?
I'm running the 1350's.
I've read where they say the 1350's will bind up before the 1310's. But really dont thinks its that big of an issue. However I could be wrong. Its happened once before...
I dont know what size lift the shafts are good too. Just from looking at them at full drop I would guess, a 4" lift would not be an issue. I keep meaning call Fulltraction and ask.
I plan on going to the 4" long arm, as soon as money will allow me. So I guess I should find that out!
