Steel coil spacer question
Old Jan 7, 2012 | 08:46 PM
Delux2769's Avatar
Default Steel coil spacer question
I have been seeing several steel coil spacers online while searching for a 1 1/2-2" budget boost.
Would the ride be rougher than the poly coil spacers?
I am not looking at the TF budget boost because $350+ is NOT budget for me.
I'm looking to spend under $125 for the coil spacers. I'm not interested in a leveling kit because I already sitting level with my Rubi takeoffs.
I've looked at Rusty's, but after $35 shipping, price for the front and rear 2" is at $110.
The steel coil spacers have a couple extra things that I'm not sure exactly are.
Old Jan 7, 2012 | 08:50 PM
armycop's Avatar
As long as you keep the factory isolators, the steel ones should be ok, never heard of anyone using them though... Those are shock extensions in the pictures, you bolt them on your factory shocks.
Old Jan 7, 2012 | 09:42 PM
wayoflife's Avatar
JK-Forum Founder
what he said. i have installed steel coil spacers and, so long as you make sure to keep the factory isolators, you'll be fine with them
Old Jan 7, 2012 | 09:52 PM
bwayers's Avatar
I received that exact kit for Christmas. I'm not going to install it until I have the money for tires though. Also, want to purchase some add-ons for it. Probably buy an adjustable front track bar, rear track bar bracket, brake line extension brackets.
That lift will be 2.5" front and 2" rear
It's possibly built by Rough Country bc they use steel for their spacers.
There are numerous members here that run the RC spacer lift without any issues. The ride should be the same as with other spacer lifts.
If i were buying it myself from the beginning I would just buy from Rough Country and get the series II kit to have the rear track bar bracket and sway bar links
