After Procal question. 2012 auto on 4.10's and 35's
Trying to reset my 12. I am running 315.75.16 MTR's. I measured them at 34.25 in height from the ground and on the jeep with full weight. Gave it a go to see my rpm's at 70 and came in at almost 2700 rpm. Jeep is an automatic on 4.10s.
2700 rpm seems high to me and the 12 conversion chart shows I should be running around 2200 to 2300. Whats everyone else seeing after ProCal with this set up?
Thanks.
Thanks.
Originally Posted by Raiderfan001
Are you supposed to measure the tire from the ground? I thought they measured the circumference.
If these are the same ones they have it as a 34.8" http://www.4wheelparts.com/Tires/LT3...n=GDY750554326
I had 315/75/16 MTRs on my '07 and they measured 34.25 on the ground, so you're ok there. I've got trail grapplers on my '12 measuring 33.75 on the ground. I've also got 4.10 and with stock tires, I ran about 3,000 rpm at 70 mph. With the trail grapplers, I'm around 2,500 rpm at 70 mph.
My 2012 (4.10 gears, BFG 35" tires that measure 34" mounted, and ProCal) is running about 2350 rpm at 70 mph. I don't understand the wide rpm ranges getting posted with similar diameter tires and gearing unless the ProCal programming didn't work.
I have a Manual 2012 so I didn't have an rpm issue but I did have a speedometer/odometer issue. I found on here somewhere that you're supposed to only measure to the top of the shoulder from the ground. Not all the way to the top of the tread, this gave me around a 1/2 inch difference in where mine was set and how it is set now. This change has seemed to fix my problem. Let me know if this helps.
