Is Rear Track Bar Adjustment Required on 2" Coil Spacer BB?
Old Jan 11, 2012 | 07:54 PM
RockShox's Avatar
Default Is Rear Track Bar Adjustment Required on 2" Coil Spacer BB?
I'm planning on installing a 2" BB on my DD. Some of the kits have a rear track bar bracket, some do not.
My plan is to use 2" coil spacers, break line extensions, shock extensions and rear sway bar links on the front.
So my question is: How important is the adjusting the rear track bar on a 2" lift?
Old Jan 11, 2012 | 08:31 PM
JfK's Avatar
JfK
I believe this will throw the axle about 1/4" off center? I am not positive, just thought that is what I read.
Old Jan 11, 2012 | 08:34 PM
ChopN's Avatar
That's correct. You will be just fine without it. Plan on a rear bracket and a front adjustable for your next purchase.
