will i have esp issues with bumper and winch install
Old Feb 9, 2012 | 12:59 PM
Grimmjpr's Avatar
Default will i have esp issues with bumper and winch install
I have a RR XHD front bumper with ends and hoop and a Warn 9.5 cti-s going on this weekend. I also got heavier front springs, but they wont be here till next week. Will i have issues with the esp if the front is sagged a bit till i get the new springs on? Thanks in advance.
Old Feb 9, 2012 | 01:18 PM
JK-UTE's Avatar
You shouldn't have any issues at all... but then again.... who knows?
Old Feb 9, 2012 | 01:52 PM
mt shawn 37's Avatar
I have no issues have an xhd front bumper and 12k warn winch
Old Feb 9, 2012 | 01:56 PM
DanieltheManual's Avatar
Just zero your steering wheel by adjusting your draglink
Old Feb 9, 2012 | 02:10 PM
JnT's Avatar
JnT
Extra weight on the front should have zero affect on your traction control system.
Old Feb 9, 2012 | 02:31 PM
Zombie Hunter's Avatar
With that amount of steel on the front, you may have issues with your Extra Sensory Perception.
I ran mine for about 1200 miles after front bumper, winch and rear bumper/tire carrier. Zero issues.
After the lift, I had to get the steering wheel centered near perfect as possible.
I now have my ESC turned off using the "steering wheel dance".
Old Feb 9, 2012 | 05:14 PM
RckyMtnGoat's Avatar
Had an exact setup on my 08 two door rubicon, only difference was I ran a 9000 warn. No problems had put close to 30000 miles on it with stock springs, it did sag a little but didn't change how it handled, that changed a little with the 35" tires and 2.5 Teraflex budget lift but that was because of the bigger tires and it wasn't anything unmanageable, good luck and have a fun install.
