10 mpgs.
Old Feb 12, 2012 | 10:42 AM
defierro's Avatar
Default 10 mpgs.
Okay, I don't want this to be another "why doesn't my JK get as good gas milage as my wife's prius". I get 10 mpgs and I just want to get a few more, I was reading a lot of members get better milage with the same set up I'm running. I'm driving 70% city 30% highway.
2dr
35 toyos
2.5 in lift
Front and rear xrc's with spare carrier
Full spare
410's
Automatic
Any suggestions, besides the whole "get another vehicle" comments?
Old Feb 12, 2012 | 10:47 AM
Atch's Avatar
Did u get a programmer to adjust your speedo?
Old Feb 12, 2012 | 10:51 AM
defierro's Avatar
I have not done that
Old Feb 12, 2012 | 10:54 AM
Saharaunlmtd's Avatar
Then you are probably getting 1.5-2.5 mpg's better than what the jeep is reporting.
With an auto, recalibrating will also correct the shift points.
Other than that, regear.
Robar's Avatar
Then how are you calculating 10mph? With out the tire size and spedo being calculated correctly you are not accurately counting the number of miles being driven.
SilverJK12's Avatar
Get superchips or similar. It's almost a must
Atch's Avatar
Since its an auto at the very least get an aev procal $150, this will adjust your shift points to make up for the larger tires and adjust the speedo, you should see a couple more mpgs
Old Feb 12, 2012 | 11:03 AM
JPop's Avatar
You need a programmer to get your speedo and odometer correct. It will also correct your shift points and help you regain some efficiency. You can't properly measure mileage when you don't have good data to calculate from.
You're also under geared which will rob you of efficiency. You're vehicle is trying to move under acceleration before you even get past the stall speed of the Torque converter. Roll out slower from standing starts and turn OD off for highway cruise speeds of 65mph or more. That'll stop the gear hunting on mild grades which is creaming your efficiency.
Old Feb 12, 2012 | 04:00 PM
Ryan0260's Avatar
True. And also the performance tunes can help bring back some of the lost power
Old Feb 12, 2012 | 04:20 PM
shawlzy's Avatar
Procal worked out great and its super easy to use.
