Teraflex 2.5 BB additional work?
Old Feb 13, 2012 | 12:05 PM
XTHEKIDX's Avatar
Default Teraflex 2.5 BB additional work?
Hey all, was wondering if there is any additional work that needs to be done when installing the Teraflex 2.5 BB system? Was concerned with brake lines, gas lines, etc:. Was also wondering how durable the shock extenders are? I live in downtown Chicago so the most off-road they see is a gravel lot.
Old Feb 13, 2012 | 12:23 PM
TEX-AG's Avatar
ive had the 2.5 BB for 2 years now, its a solid lift, comes with everything you need, brake line extensions, rear track bar extension, etc.
Not familiar with the shock extensions, i added aftermarket shocks.
I have noticed quite a bit of droop in my front springs from adding a bumper and winch in december. Bump stops are almost touching without flex, so im gonna have to do something about that soon.
Here a before and after for you reference:
Name:	Stock to TF2.5BB.jpg
Old Feb 13, 2012 | 12:59 PM
XTHEKIDX's Avatar
Which lift lit did you get??
Old Feb 14, 2012 | 02:05 PM
TEX-AG's Avatar
im running the 2.5 spacer lift. I bought the one with shock extensions and ended buying aftermarket shocks anyway.
Old Feb 14, 2012 | 02:49 PM
TeraFlex's Avatar
Sponsoring Manufacturer
You really won't need to add anything to this kit. Unless you have a 2012 then you will need the #2610000 exhaust spacers. Grab a set of used Rubicon shocks if you want a firmer ride. Give me a call if you need to.
