Plow?
Old Dec 2, 2007 | 05:16 AM
WRAITHYJEEP's Avatar
Default Plow?
any one have a plow on yet?
was looking and it seems that some companies do have a mount for the jk out.
snow bear and related subsidiaries.
thinking that my lift springs with be able to handle the added weight.
Old Dec 2, 2007 | 08:24 AM
monkemeier's Avatar
Default Just tried my new plow
Heres a picture of my X with the Snoway 22 plow on it. Not much snow to plow, but it worked great. I will be adding Timbren spring helpers to keep the front from sagging.
Ed Monkemeier
Old Dec 2, 2007 | 10:12 AM
TexsDream77's Avatar
Fisher makes a plastic snow plow for the Jeep JK. It's the homesteader. Very, very light. It won't weigh the front down much at all... no need for helpers or changing to winter tires. Down side is they are not cheap and almost impossible to find used. If you do find a used homesteader... don't worry about what it came off of... you can get the new mounting brackets for the Jeep anywhere.
Old Dec 2, 2007 | 10:51 AM
jblankster's Avatar
i want to get a plow since i snow blow about 6 driveways now... and it sucks when its slushy snow. but i still want a lift and dont know if itll still work.
whats the max lift i can get with a plow?
Old Dec 2, 2007 | 12:43 PM
Embalmer's Avatar
dont think the new plow mounts for the jk's were designed for lifts, thus probably wont work with a lift. same concept of why you dont see trucks with lifts with a plow
Old Dec 2, 2007 | 01:06 PM
twinturbostang's Avatar
Not ture for all lifts. Yes a big lift say 6+inch its hard to get the plow right but and can be done.
As for a 2 or 3inch lift with a Boss plow you can lowere the main bar to the needed point and still plow just the same.
We have mounted plows on 6inch+ lifted truck but it more money than most would want to spend since you need to fab everything.
Old Dec 2, 2007 | 01:08 PM
Also go here you can see a boss we mounted on a JK last winter
https://www.jk-forum.com/forums/jk-talk-26/recent-snowplow-developements-jk-16217/
Old Dec 2, 2007 | 01:11 PM
That other thing about putting a plow on a lifted Jeep or truck is that it kills the whole point of lifting the truck because you end up with a very low bar right under the front bumper.
Old Dec 2, 2007 | 03:24 PM
drbeddow's Avatar
Originally Posted by putnam dan
if you go offroad with the plow attached your nuts!!!!! I think most people who use plows do it seasonally so the low bits come off when wheeling.
Old Dec 2, 2007 | 03:35 PM
The mount on the truck itself always stays on the truck, and that is the low part.
