lift with electronic disco sway bar
Old Mar 1, 2012 | 08:05 AM
the_cuse420's Avatar
Default lift with electronic disco sway bar
What needs to be done. I just got an 08x with it and rear locker. Any advice would be very helpful.
Old Mar 1, 2012 | 08:09 AM
wecf's Avatar
What is the problem? It's hard to help if we don't know the question.
Old Mar 1, 2012 | 08:20 AM
What needs to be done with sway bar connects to make a 2.5 lift work or what problems may occur
Old Mar 1, 2012 | 09:24 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Typically a 2.5" kit will reused the stock longer rear links when new links are installed in the back. The e-disco will work just like normal still.
Old Mar 1, 2012 | 09:26 AM
wayoflife's Avatar
JK-Forum Founder
what joe said. so long as the links are long enough, you will be able to use your e-disco just fine and without any problems. for 2.5" of lift, the factory rear links should do the job.
