Fabtech lift?
Old Mar 20, 2012 | 09:42 PM
reid9922's Avatar
Default Fabtech lift?
does anyone have a 3" basic or a 5" short arm Fabtechh lift. is it a good lift? wats your recommentadion
Old Mar 20, 2012 | 09:53 PM
wayoflife's Avatar
JK-Forum Founder
5" is A LOT of lift and not one i would recommend unless you were planning on running 37" tires or bigger and certainly, not as a short arm kit. IF you get this kit, make sure to have the track bar relocation brackets welded up with extra gussets as i have seen more than enough tear off the factory mounts right off the axle and cause all kinds of death wobble.
