View Poll Results: 35's / 4.56
Run 35's and 3.21 till I can afford the gears
5
33.33%
Run 4.56 gears until I can afford the 35s
2
13.33%
Wait and get both at the same time
8
53.33%
Voters: 15. You may not vote on this poll
3.21 and 35's suck, Video/how bad?
Old Apr 8, 2012 | 02:30 PM
TCJK11's Avatar
Default 3.21 and 35's suck, Video/how bad?
So here's the deal. I know its going to suck, but I'm not going to be able to afford the lift, wheels, tires, and gears all at once. I'll be driving around on the sporty wheels and tires w/ 2.5'' lift for a while, it's gonna look goofy, but I'll be saving for wheels and tires. My question is, should I get the 35s first or the 4.56 gears first?
Does anyone have any video of just how bad 3.21s are w/35s? I drove a Chevy Tracker for years while I was saving for my jeep and it was slow as all get out, but it got the job done. I can't imagine its going to be worse than that. Living in Louisiana, everything is flat and just above/at/below sealevel so elevation is going to be a problem.
So what do you guys think? Should I just wait and do it all at once, or put it together as I can?
Old Apr 8, 2012 | 02:51 PM
jkd3624's Avatar
I have 3.21 and 35's. Highway I can't use 6th gear. Do u have standard or auto?? On trail not bad but can't use 4hi. As much as everyone says they suck they aren't that bad it works for me for now. Search utube for jeepdutton might beable to see a video of my jeep on some rocks at rausch creek.
Old Apr 8, 2012 | 02:52 PM
aldaman's Avatar
I ran 33s with the 3.73 for a while before I changed to 5.13 gearing. Even with the 3.73 I didnt like the drive/performance. I couldnt imagine how you would feel with 3.21s. Do you have an auto or manual. If you have an auto, to me it would totally suck. I would get the gearing first and 35s later. At least that way you can have fun with the added uummmpppphhh the 4.56 gearing gives you with the stock tires....
Old Apr 8, 2012 | 02:57 PM
aldaman's Avatar
I looked at your profile and see that you have a manual. In that case you'll probably be okay if you choose to get the 35s with out regearing. It may be sluggish off the line and you will probably only use 4th - 5th gear most of the time. But having a manual you have some sort of control with the RPMs and shifting even with the 35s....
Old Apr 8, 2012 | 03:01 PM
OC-JK's Avatar
I have 3.21 with 35 km2s, manual trans. It's not as bad as I expected. But I don't drive fast. It works until I go bigger then ill regear.
Old Apr 8, 2012 | 03:02 PM
TCJK11's Avatar
What's your jeep look like? I'll see if I can find the video
Right, 6 Speed Manual.
Old Apr 8, 2012 | 03:09 PM
aldaman's Avatar
Worst case scenario is if you get the 35s first and you dont like the performance you can always store those tires, run your stocks until you have enough money to regear....At least you already took care of getting the 35s and allow yourself to then move to the next stage and start saving for the regearing....
Old Apr 8, 2012 | 03:15 PM
Mark73's Avatar
Wouldn't 4.56 gears and small sport tires rev really high ? Thinking ?
Old Apr 8, 2012 | 03:23 PM
aldaman's Avatar
I ran 33" tires with the 5.13 gearing for a while...The tires actually measured ~31" and my RPMs were around ~2800 - 3000 at 60mph (cant recall the specific RPM)...I found that okay granted I only do city driving, plus the 3.8 engines love being at that RPM range...
Old Apr 8, 2012 | 03:32 PM
Mark73's Avatar
My sport came with 235 75 r 16
