Post lift knocking
Old Apr 19, 2012 | 11:05 AM
JE8154's Avatar
Default Post lift knocking
So I've had my lift on for a couple weeks now and I've been noticing some knocking and clicking coming from the back end when I go over anything uneven. Anyone have an idea on what I should check?
Old Apr 20, 2012 | 06:27 AM
stix's Avatar
Could be sway bar end links. What type of lift did you get?
Old Apr 20, 2012 | 06:28 AM
GaMtnJk's Avatar
Might have put your rear bumpstops on backwards. Any slight bump makes a clunk....Don't ask me how I know
Old Apr 20, 2012 | 06:53 AM
CDN-JK's Avatar
Tighten your sway bar links. Definitely the problem.
Old Apr 20, 2012 | 07:08 AM
Croce's Avatar
I had the same issue in the front, was also the sway bar links
Couldnt hurt to retorque your trackbar too while you're under there
Old Apr 20, 2012 | 10:22 AM
djab's Avatar
Could be the rear track bar hitting the rear passenger side spring. That's what mine was doing. Bought the Rock Krawler wedges and it fixed the problem.
Old Apr 20, 2012 | 10:24 AM
djab's Avatar
I had to tighten the sway bar links as well. I isolated the problem by having a buddy rock the S out of my Jeep while I looked around.
Old Apr 20, 2012 | 01:25 PM
JE8154's Avatar
It's a 2.5" teraflex, and it does kinda sound like something hitting the spring. I'm gonna check it tomorrow and tighten everything. Thanks guys.
Old Apr 21, 2012 | 06:18 AM
JE8154's Avatar
this is the problem. Rear trackbar is making direct contact with the passenger side spring.
