Best 2" Lift Kit
I just got my 12 JKU. I want to do a 2" lift. I'm only going to run 33's or 34's. Whats the best kit for a 2" lift that will still be a nice ride for daily driving. Will do some mild off roading as well nothing extreme.
I"ll spend the money for whatever is the best quality in the long run. I had a full traction 3" priemum on my 08. But not going that extreme on this one. I Want the ride to be stock or nicer.
Originally Posted by Canuckjkjeeper
i just installed the Teraflex 2.5" Budget Boost on the weekend and Bilstein 5100's.....i must say that it handles and rides much better than the stock Rubicon shocks. Cheap and effective way to fit 35's for a daily driver. I had zero issues with the install and the steering wheel stayed centered and no shakes or wobbles.
If you want just a 2" kit, then you can go with either the #1155200 BB Leveling kit ($136.99) or the #1351500 coil version ($409.99). Both will retain your factory shocks, the BB kit will ride like the stock vs. the coil kit will be a little firmer.
Originally Posted by Rock Krawler Suspension
You could always just start with some good coils and shocks at that small of lift height and start adding components as needed...
RK
RK
$450.00 was the total for me. I bought the 4 Bilstein 5100's slightly used off of another member for $200.00. The TF kit that i bought ( no shocks or adaptors ) was $250.00.
Took me and a buddy approx 3.5 hours with the help of a hoist and air tools. Very easy install.
