2.5" tera flex +1" teraflex coil spacers... possible issues?
Current setup is a 2012 4 door, 2.5" teraflex coil lift with 9550 shocks, coast 1310 front drive shaft...
Anyone have any insight as to any issues that I might run into adding 1" coil spacers to my existing lift?
You said you already have a driveshaft and thats the major problem... I have a 2.5 teraflex with a 1 inch teraflex coil spacer in the front. I also have a 1 inch bodylift. My only problem ive experienced is my driveshaft is going bad but you wont have that problem if you already replaced it with aftermarket. Here is a picture...
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=308846"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=308847"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=308848"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=308849"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=308850"/>
I just lifted mine in the past month or two and I ran in to a couple of items. I had to replace my driveshaft (which you've done), I extended my brake lines (too short) and I finally added a front adj trackbar. ideally I should be replacing some control arms, but probably won't do taht anytime soon.. Trackbar was also debatable if it "had" to be done.. Brake lines are a must though...
