new 3.25 lift and now I have wobble issues
Old Apr 24, 2012 | 02:19 PM
talorek's Avatar
Default new 3.25 lift and now I have wobble issues
I just spent the weekend under my 2010 4 door jeep wrangler installing a 3.25 inch lift with 35 inch tires. I had a great weekend but now I am trying to work out all the bugs. When I get up to 30 mph the whole truck begins to wobble.
I think one of the biggest issues I have is caster angle. I adjusted the control arms to suggested leingths but I think my angles are off. What is the proper caster angle for the front and rear axles? I also know that the steering is not alligned any more. Does this need to be done in a shop with computers or can it be done by me?
Thank you for all the info.
Old Apr 24, 2012 | 04:41 PM
Myjeep2012's Avatar
I'm no expert here but the first thing after a lift you should get is an alignment and then go form there.
Old Apr 24, 2012 | 04:54 PM
GreenJK07's Avatar
You should have an alignment completed right after the install. If the problem persist, then check all of your bolts and make sure everything is snug. I would start with the trac bars and then move to control arms, etc.
Old Apr 24, 2012 | 05:19 PM
jeep2007's Avatar
For front I would start at 23" for lower. Make sure your axles are centered. I run this kit and have zero issues for more then a year. I have my frt lowers set at 23.25".
Old Apr 24, 2012 | 05:20 PM
jeep2007's Avatar
I assumed it was a Rusty's suspension.
Old Apr 24, 2012 | 05:58 PM
Bronco_Bustin's Avatar
Over-torque your panhard bar to like 140ftlbs. Fixed mine
Old Apr 24, 2012 | 06:00 PM
Ryan0260's Avatar
Yeah same here. Never had an issue with mine...
Old Apr 25, 2012 | 01:34 PM
talorek's Avatar
Thanks for the info. Yes it is Rusty's lift. the instructions say 22.5 inchs on the front lowers but I can now see that this is really short. My driver side spring buts up to the quick disconnect. I am going for an alignment tomorrow. I hope the shop is able to do proper adjustments. If not I know I need to start by increasing my lower control arms. Once again thanks for the help.
Old Apr 25, 2012 | 07:47 PM
mfkb's Avatar
Give Rusty's tech support a call. Let us know how everything turns out and what the fix was.
