Tru trac in front and back
Originally Posted by lopezv123
I'm confused... Thought the stock "limited slip" was the tru trac system, no?
The Truetrac uses gears which last longer and are often biased to engage more quickly.
Factory uses a Trak-Lock in the back .. not a Tru-Track ... the factory one uses clutches that wear out pretty fast .. most people call it a TRASH-Lock ...
If you don't want to lock the front ... the best alternative is Detroit Locker in the back and a Tru-Trac in the Front.
I have driven many vehicles with LSDs front and rear, mostly Subarus but my CJ7 had that setup (Quadratrac), and the Trak Lok i had on my 2010 was by far the least effective LSD I had. Not because it has clutches or anything, just not a good product. I have lockers in the rear now and have not noticed it is gone.
If you don't do rock crawling LSDs are great on the trail.
I run this set up and it's awesome, for my conditions. You could do other things that are economical (Aussi, Detroit) that might fit your situation better. What do you need a traction aiding device for, what are your goals other than economic etc.
