New JK owner/ what is this?
Old May 3, 2012 | 07:06 PM
Lutz's Avatar
Default New JK owner/ what is this?
Just bought a 2dr 2010 sahara, was looking at jeep and realized it has 2" spacers with no badging on them.
My ? Is what lift is this, and am I missing some important parts?
Correct me if I'm wrong but there is no extended bump stops, factory sway bar links, and factory shocks, and no front coil isolators.
Front:
Rear:
Rear link:
Front link:
rear bump:
Old May 3, 2012 | 07:13 PM
ssg381's Avatar
Did you not thoroughly inspect the Jeep before purchasing it
Old May 3, 2012 | 07:18 PM
Lutz's Avatar
Yes but is my first jeep and it looked like stock hardware, didn't know what to look for
Old May 3, 2012 | 07:56 PM
finfreeze's Avatar
Looks like a 2.5" front spacer and a1"rear spacer. Basically a what the lift companies call a budget boost or leveling kit.
The front spacers look like the tera flex spacers I had on the front of my jeep. I ran front spacers and nothing else for 2 years and went places I shouldn't have with stock mudders and never had a problem.
You should be fine.
Old May 3, 2012 | 09:05 PM
Hudweiser's Avatar
I just lifted my JKUR with a rough country 2.5" suspension lift that did not come with:
bump stops,
sway bar links, and
I am running the stock front and rear sway bar links and was thinking about getting some stock rear sway bar links to swap out for the stock fronts. But now I am wondering if I need anything else that my RC lift did not include.
Thoughts?
Old May 4, 2012 | 02:09 AM
NewfieScreech's Avatar
Yes, as the others above me said. It's just a budget boost. No big deal about missing the bumpstops. If you want them you can buy another budget boost online for a little over $100 and use the bumpstops in it. You don't need them though.
I had issues making long right turns (like an on-ramp) after my budget boose because the ESP would kick in and kill the power and apply the brakes because it thought it was skidding. I ordered a Procal Chip and installed it. After that it ran perfect! Just saying incase you experience the same thing.
Old May 4, 2012 | 05:00 AM
Lutz's Avatar
thanks guys, you have been very helpful...i look foward to being on this forum everybody seems to be very helpful
I thought about upgraded shocks, and sway bar links? worth the $$$?
Old May 4, 2012 | 05:17 AM
mattgt5's Avatar
Sway bar links = no
Shocks= probably. the stock sport/sahara shocks are not the greatest ever
Old May 4, 2012 | 05:30 AM
Rule18's Avatar
Originally Posted by mattgt5
Sway bar links = no
^----- X2 for sure. As a starting point, you might look at Bilstein or OME (Old Man Emu). In case it's not clear, the previous owner would have installed the leveling kit because a stock JK has a pretty significant front end rake to it.
Old May 4, 2012 | 05:45 AM
Atch's Avatar
I'm gonna say sway bar links IF u plan on offroading, I'd recommend getting some quick disconnects--no tools needed to disco this way
