My DIY front & rear bumper pics
Old May 3, 2012 | 08:23 PM
07XMan2Door's Avatar
Default My DIY front & rear bumper pics
Just got done building me a set of bumpers. Used 6 inch channel. 1/4" thick. These things are stout.
Ordered the D-Ring mounts from Cutthroat4x4 Awesome people. Killer product.
They took the time to key the tabs through the 1/2" plates & weld them from the back side as well.
Old May 4, 2012 | 05:45 AM
Johnny_t's Avatar
Looks good. Love to see custom fab'd stuff.
Old May 4, 2012 | 05:56 AM
Wood82ABN's Avatar
I like it! What was the total cost?
Old May 4, 2012 | 06:35 AM
webejeepin's Avatar
Agreed, custom fab stuff is great, nice work!
Ya, I'd like to know too what this ran you cost wise....if you don't mind me asking.
Old May 4, 2012 | 08:03 AM
Thanks Jonny!
Thanks Sir!
Appreciate that. The only steel I had to buy at the scrap yard was the 6" channel. So 40 bucks for the front & rear.
Her is a close up of the end. I cut up a huge allen wrench & welded it to the bottom. I spaced them so my Hi-Lift Jack would sit in there & not slide off.
These are 1/4" plates I cut out for the push bar mounting plates. I had them on hand.
This is a pic of the winch mount plate that I got when I bought my winch from a neighbor. He sold me his brand new Smittybuilt winch, with 100ft syn line, 2 winch plated, hause fairlead & a cover for 300 bucks.
His Jeep was a TJ & the mount bolted to the top of his frame. I actually could have used his plate in the same manner but wanted my winch to sit much lower. So I cut it up & dropped it 6 inches.
Here it is bolted to the 2.5" channel on the bumper.
So All in all for both bumpers
Steel=40 bucks
Winch=300
Dring mounts, all 4=160 wasn't going to go cheap here. I bought the best I could find
Grade 8 hardware=20
Paint & primer=15
535 bucks for both bumpers & a winch!! Not bad!
Thanks for the kind words Guys!
Old May 10, 2012 | 04:04 AM
jr_clark84's Avatar
What did you use to attach the rear bumper to the frame?
Old May 14, 2012 | 07:55 PM
I welded three inch channel to the bumper. Two 1/2" grade 8 bolts went through the channel on both sides of the frame.
Two of the D-Ring mounting bolts went all the way through the frame. Also, two 1/2" bolts went from the rear of the hitch to exsisting holes in the frame.
If you need pics let me know.
Here's a pic of the three inch channel bolted in place, prior to welding it to the bumper.
After they were welded on.
Old Jun 1, 2012 | 05:10 AM
nateman73's Avatar
really like the clean look of these...subscribed and on list
Old Jun 1, 2012 | 08:01 PM
Thanks. I really wasn't happy with the hitch so I spent AN HOUR cutting & grinding it off. Then I cut a 2.5x2.5" hole in the face of the bumper & welded a piece of hitch tubing in. Welded front & rear. Very very strong. Then I built a slimmer slider.
Here's the slimmer slider:
Thanks for the kind words Sir.
Old Jun 1, 2012 | 08:05 PM
Greep's Avatar
The question is... When do you start taking orders?!? These bumpers are awesome!!!
