e-Locker lights not on...HELP
Old May 9, 2012 | 09:34 AM
JKBobAZ's Avatar
Default e-Locker lights not on...HELP
I have done the "Override" mod so that I can lock the factory e-lockers with out going into 4-lo
What has happened is that the lights on the dash are not coming on the dashboard even if I push the factory button or my mod'ed one.
I am running Aero-Force gauges and a DiabloSport tuner. I know the Diablo allows you to turn the sway bar lights on and off but see no set up for the locker.
I am sure it is something I have done!!!! any ideas????
FYI the lockers are engaging even though the lights are not on!!!
Old May 9, 2012 | 11:04 AM
ronjenx's Avatar
There are several ways to do this mod. Which method did you use?
Old May 9, 2012 | 01:15 PM
JKBobAZ's Avatar
https://www.jk-forum.com/forums/jk-w...ication-88085/
I grounded the 2 relay's next to the battery box.
Old May 9, 2012 | 01:26 PM
ronjenx's Avatar
Is this on one...or both lockers?
When did you start seeing the light not coming on? Was it ever working as it's supposed to after the mod?
Old May 10, 2012 | 07:21 AM
JKBobAZ's Avatar
The lights worked for months (both when the added switches were engaged and when the OEM system was engaged)
I think it has somting to do with the AeroForce or the Diablo but I cannot find any settings for the elockers only for the sway bar discos??
Old May 10, 2012 | 08:57 AM
grandpa jeep's Avatar
This is why I don't mod computer sh!t. It seems like it never works out
