Passenger Side Leak 2012 JK
Had a nasty storm today while my soft 2012 JK was sitting in the driveway. Headed for the store and looked down to see some water on my rubber floor mat. Got home and investigated to find the carpet was damp running along the door frame. Just wondering if any of you have had the same issue and what it might be and what route I should take to fix it. Just worry about damp carpet and mildew/mold as I have a fan on it at the moment..
Had a small leak on that side w the hard top. Switched to the soft and no problems so far..call your dealer they usually have water leak specialists in there once a week. Good luck
Found this info on another forum.
Might be helpful to get educated before taking to the dealer.![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
http://www.jeep-club.net/graphics/ma..._Leaks_All.pdf
Mine went to the dealer 6 times for this issue. Finally fixed it. Chrysler just released a new technique to water test which is finally what did the trick on solving it. Be persistent. They'll eventually get it.
