DVD cheat?
NO! The 430N is all tied into the CanBus System of the Jeep. It communicates with the PCM to see shifter position , road speed all sorts of nanny functions. I use a "Lockpick" (Search the forums for it) and there is one more brand I cannot remember which. It enables: (From coastaletech site)
DVD PLAY WHILE IN MOTION - AUTOMATIC OR ON DEMAND
SAT TV ON FRONT SCREEN WHILE IN MOTION (IN EQUIPPED VEHICLES) - AUTOMATIC OR ON DEMAND
NAVIGATION ADDRESS INPUT WHILE IN MOTION (IN EQUIPPED VEHICLES) - AUTOMATIC OR ON DEMAND
UNLOCK EVEN DEALER BLOCKED VIDEO - EVEN IF YOUR VIDEO BUTTON IS NEVER VISIBLE THE LOCKPICK WILL EXPOSE AND UNBLOCK IT
TURN ON BACKUP REVERSE CAMERA INPUT FOR AFTERMARKET INSTALLATIONS
TURN ON FACTORY REVERSE CAMERA AT ANY TIME, EVEN IN DRIVE IF DESIRED
TURN ON A REAR SEAT BABY CAM AT ANY TIME
TURN ON A FRONT CAMERA AT ANY TIME
TURN ON A FRONT CAMERA AUTOMATICALLY BELOW 8MPH TO AID IN PARKING
OPTION BUILT IN FOR TURN SIGNAL CAMS - ACTIVATE AUTOMATICALLY WHEN TURN SIGNAL APPLIED, OR TURN ON LEFT OR RIGHT SIDE CAM MANUALLY AT ANY TIME
TURN ON VES (REAR ENTERTAINMENT MODE) IN NON EQUIPPED VEHICLES - ENABLES A VIDEO AND AUDIO INPUT FOR YOUR IPOD, IPHONE, COMPUTER, OR VIDEO GAME
AUX INS UNLOCKED IN VES EQUIPPED VEHICLES WHILE IN DRIVE
UCONNECT AND VOICE RECOGNITION ENABLED ON CAPABLE NAV RADIOS - JUST ADD A MICROPHONE AND YOU ARE READY TO GO SEE MICROPHONE OPTION HERE
NO SWITCHES TO ADD - USES FACTORY TOUCH SCREEN AND RADIO BUTTONS AND STEERING WHEEL CONTROLS
NO LOSS OF NAVIGATION USE WHILE UNLOCKED - VOICE COMMANDS AND MAP TRACKING UNAFFECTED - EVEN WHILE VIDEO IS VIEWED
ACC POWER OUTPUT PROVIDED FOR YOUR AFTERMARKET POWER NEEDS - TURNS OFF WHEN YOUR CAR TURNS OFF
CAMERAS POWERED AND CONTROLLED BY THE LOCKPICK - NO NEED FOR COMPLICATED WIRING OR EXTRA SWITCHES
PROGRAMMABLE DIP SWITCHES TO ENABLE OR TURN OFF SPECIFIC FUNCTIONS
NO CUT WIRES - 15 MINUTE INSTALL WITH PLUG AND PLAY FACTORY CONNECTORS
GREAT FOR LEASED CARS!! - UNPLUG IT AND YOUR CAR IS BACK TO STOCK
WORKS WITH ALL MYGIG RADIOS IN ANY CHRYSLER DODGE JEEP INCLUDING MANUAL AND AUTOMATIC TRANSMISSIONS - ADVANCED UNIVERSAL COMMUNICATIONS
Makes for an easy plug and play install.
The switch thats shuts off the video while driving is located on the emergency brake under the consol, There is one problem though, the brake light stays light on the dash. I haven't yet disabled mine as I am in the middle of bedlining the tub.
Originally Posted by Winterhawk
Instead of hacking up my wiring on the new 2012 Rubicon I bought a mygig lockpic Sunday for $189.00 delivered. Should be in Friday and is plug and play.
My navigation unit in my 2008 JKU Rubicon has been shutting off randomly while driving more frequently as of lately. Does anyone know if the lockpick might help with this?
On aftermarket units you have a single wire you connect to the parking brake indicator switch. If you connect that wire to a ground instead, the unit thinks you are parked and will play the DVD’s while you’re in motion. I don’t know about stock.
Coastal E Tech MYGIG LOCKPICK v.4 Chrysler Dodge and Jeep Navigation Unlocking Device (MYGIGLOCKPICKv.4) from Solid Signal
$199.00
It showed up today and I installed it. Works great after a few setting changes. Instalation went ok. The grey connector didn't seam to lock in place so I used a couple of small zip strips to snug it up.
After I hooked it up I turned the key to on I got a securuty screen wanting a security code. I called the Jeep dealer and know one knew anything. After starting the Jeep it turned on perfect. I guess the Computer needed the Jeep to be running to read the system.
Mine is a 2012 Rubicon 2 door
Coastal E Tech MYGIG LOCKPICK v.4 Chrysler Dodge and Jeep Navigation Unlocking Device (MYGIGLOCKPICKv.4) $199.99 1 $199.99
Checkout - Expedited Order Processing $1.99 1 $1.99
Shipping Method: Ground
Subtotal: $201.98
Shipping Charge: $0.00
Sales Tax: $0.00
Other Discounts: - $0.00
Order Checkout Total: $201.98
$199.00
Subtotal: $201.98
Sales Tax: $0.00
NO The lock pick only unlocks the locked features. DVD, input nav, cams all when your driving. For your problem I would do an update of the system. Get the latest software and update before you have bigger problems.
