Cant get muffler off!!
Old May 11, 2012 | 05:08 AM
NJ-RUBICON's Avatar
Default Cant get muffler off!!
I was trying to get the stock muffler of my 09 and can not get the hangers through the rubber grommets. I was under the truck for 3 hours yesterday trying to push them through. No luck. I used soapy water and still nothing. Anyone know how to get the stupid hanger out. Thx
Old May 11, 2012 | 05:10 AM
HELLBENDER-JK's Avatar
A rubber mallet might help!
Old May 11, 2012 | 05:18 AM
afpilot82's Avatar
JK-Forum Ambassador
You can pick up some exhaust hanger removal pliers or just beat on it. Check you local auto parts store.
Old May 11, 2012 | 05:21 AM
DanieltheManual's Avatar
Channel locks work
Old May 11, 2012 | 05:23 AM
Jhouse93's Avatar
I used neversieze just for the slickness and a big pair of channel locks and pinched it together till they popped through and did the same to get the new ones on took about 2 min for each hanger
Old May 11, 2012 | 05:53 AM
NJ-RUBICON's Avatar
Originally Posted by DanieltheManual
Channel locks work
I tried channel locks and nothing. They are not that big but still was a pain and got no where
Old May 11, 2012 | 06:23 AM
12mile's Avatar
Yep, real pain, i used Silicone based lubricant,
Superlube and finally got mine out. Definitely was more of a hassle than i was expecting
Old May 11, 2012 | 06:34 AM
kh202's Avatar
Yep soak some WD40 on there and they'll slide right off. Have to put some muscle into. Lol try ky!!
Old May 11, 2012 | 06:46 AM
NJ-RUBICON's Avatar
As for the hanger removed pliers no auto part store around here has it. This would a lot easier if I had a lift. Layin under the jeep is killing me
Old May 11, 2012 | 06:56 AM
Dynomax's Avatar
Sponsoring Manufacturer
They can be a PITA.
As has been stated soak them with WD40, PB Blaster or the like.
You can use a pry/crow bar as well for leverage as well.
Good luck!
