Coilover vs standard sping lift
Somebody please break down the pros and cons of a coil-over system vs standard spring lift. I keep getting mixed info. I hear the flex is better on the coil-over then I hear its not any different than a spring lift and that the coil-over are just for tuniblity. So wtf why would one want a coil-over?
Originally Posted by gonwhln
flex is not a hugh difference, depend on your oter components. ride is fantastic and so is the speed you can go offroad.
pros: awesome look, great ride, tuneable, trick upgrade, speed over rocks/whoops, height adjustablitly for later mods, rebuildable for life long purchase.
cons: expensive, need to modify and weld, tuneing can be tricky with trial/error method.
speak for yourself - not all coil over kits offer the same performance. some like your's only offer a total of about 9" of vertical travel while others, like the kind made by off road evolution offer a true 14" of vertical travel - see below...
even the new off road evolution bolt on coil over offers a true 12" of vertial travel up front and 11.25" in the rear...
i have yet to see any standard spring kit or coil over kit made by any other manufacturer offer flex and/or performance like this. but hey, that's just me.
coil over pros:
• offers superior flex - as much as 14" of vertical travel
• offers superior absorbsion from high speed hits
• when dialed in properly - will offer superior ON ROAD performance and comfort
• fully adjustable (including ride height) and completely rebuildable
• valving can be set and adjusted to meet your ride quality standards
• 2 separate spring rates can be selected to help provide ride comfort and weight carring capacity
• can be run with additional triple bypass shocks to significantly increase high speed desert driving
coil over cons:
• with the exception of the new off road evoultion bolt on coil over system, they can be very expensive
• requires periodic maintenance that should be done by the manufacturer
Thank you ! That helps alot. Now does a certain someone ( WOL ) know When the new EVO bolt ons are going to be released??? soon I hope
Get over there SPeed Em up...: I cant wait much longer!
unfortunately, i don't know for sure when it will be out. all i know is that they are trying to build up inventory so that when it is officially released, they will have kits ready to ship. if i could guess, maybe by the end of the month.
A related question : Specifically for going fast over rocky uneven terrain, why is a coilover better ?
Both set-ups (coilover vs coils+shocks) have the same basic materials - a spring with a shock absorber - so I've wondered is the benefit that a coilover strut reacts quicker to high speed terrain changes than a regular coil with shock absorber ?
Cheers
Cheers
