Front or Rear Locker First
I'm leaning toward installing the front locker first in my 2011 JK Sport. Since it has limited slip in the rear, I think this might be the way to go. I will eventually install a rear locker. I've talked to several off-road shops about this. They seem to be split 50/50.
I do use this Jeep off road. I've made a trip to Moab last year and have another planned soon. I also head to Death Valley once or twice a year and hit the deserts in southern California regularly.
Thoughts?
Thoughts?
Tough call. LS is a decent traction device but it is NOT on the same level as a locker. I hardly use my front locker as I find my rear locker is usually more than adequate. I go over things with ease with my rear locker engaged that others with LS have major trouble with. The front locker is nice on rock climbs that require zero wheel turn. Other than that, I find it annoying and never use it.
Question for you, do you have any plans to regear anytime soon? Most that install lockers will tend to regear at the same time since crap needs to get opened. Your setup doesn;t scream the need to regar but just throwing that out there.
And, yes, I understand that a LS and a locker are not on the same level. With my current setup, I've driven Metal Masher and several other fairly difficult routes in the Moab area.
I'll never have the money to replace the front axle, so am planning of re-sleeving the front when I do the install (if I go that way).
I put a locker in the front first on the 30. I used an aussie locker cause they are pretty cheap. I do plan on changing the front out in the feature and thats why i went with an aussie. It is a little enoying not being able to switch it on and off though and their is lots of clicking that also drives me nuts. I guess the clicking is normal for my JK. My buddy has a TJ or YJ or something around their and it does not make a peep. Thats just my 2 centavos, and good luck on deciding
