EVO 1/4 Pounder install question
Old May 20, 2012 | 11:30 AM
Capncc's Avatar
Default EVO 1/4 Pounder install question
Installing the bumper on 11 JK Rubicon. When relocating the swaybar mount it appears your drilling the new mounting hole into the casing and using the original bolt to self thread into it. Correct? I noticed there is a non-threaded hole on the casing that could be tapped for the bolt but this would put the isolater at a 90 degree angle. Opinions requested. Thanks
I went ahead an tap that flange an attached it there. Got the bumper and winch on next is lights and wiring.
ID:	319373Click image for larger version
