New swaybar links for 2.5" lift?
Old May 21, 2012 | 03:27 AM
JKmudslinger09's Avatar
Default New swaybar links for 2.5" lift?
Hey all! I just picked up a procomp 2.5" lift with shocks and coils but it didn't come with new swaybar links. Will I need new ones or can I just run the stocks?
Old May 21, 2012 | 03:31 AM
Deep Water Terp's Avatar
You can just run the shocks, but I suggest getting longer rear swaybar links and moving the stock rears to the front. You can pick some up from Roughcountry.com for $20.
Old May 21, 2012 | 03:34 AM
Thanks! What could happen if I run the stock swaybar links with this type of lift?
Old May 21, 2012 | 06:55 AM
rattymml's Avatar
I've been running my rig like that for a few months now, the only thing I've noticed is trying to reconnect them after wheeling can be a pain if you're not completely level.
Old May 21, 2012 | 06:58 AM
nortski3's Avatar
It's not an if but when. Running short sway bar links put the swaybar at a downward angle. If you wheel like this it can cause a bind causing them to bend and then there a bitch to get off depending on the severity of how the bind.
Old May 21, 2012 | 06:59 AM
keithsfd7's Avatar
On road u will be fine but if u don't disconnect them when u go off road, they can flip forward and press against your steering linkage and u won't be able to steer.
Old May 22, 2012 | 05:00 AM
Thanks everyone!! I just ordered a set of adjustable rear links and 2.5" front discos. I just wish I had the proper tools and capability to put the lift on lol.
