Hulk wheels on a JK
Old Dec 22, 2007 | 10:15 AM
Keene oh8JK's Avatar
Default Hulk wheels on a JK
Okay I have seen some Hulk (commander) wheels on a JK. My question is ... the Hulk wheel has a 50mm off set (whats the difference between off set and back spacing?) ... does this mean I would need wheel spacers? Most after market rims are 4.5" back spacing . So how are people making these work?
Old Dec 22, 2007 | 10:48 AM
TEEJ's Avatar
Talking
Back spacing and offset are related, but different.
Back spacing is the distance from the inboard most flange lip to the hub mounting face...so that the MORE BS, the tighter into the wheel well the rim is tucked (More BS = Deeper dish facing the brakes, etc)
Less backspacing is the same as adding a spacer...so less BS means the rim sticks out further outboard.
Offset is relative to THE CENTERLINE of the rim, not to the inboard flange...
The problem with only knowing ONE measurement, is that offset changes relative to rim width, and BS doesn't.
So, 50 mm = almost 2". That's 2" off of the centerline of the rim. After moving 2" from the centerline of the rim, the wider the rim, the further the distance to a flange on one side, and the closer it is on the other side's flange, etc.
An OEM 7.5" rim is 8.5" wide (They don't count the flanges when naming nominal rim widths...) so a zero offset would be the same as a 4.25" BS.
I don't know the rim width on the Hulk rim...but, using the above, you could calculate the BS, just remember to an an inch to the stated "rim width" when dividing in half to find zero offset....etc.
Old Dec 22, 2007 | 01:17 PM
JYogi's Avatar
Look around, someone posted pics of their JK with those rims a couple days ago. You can ask them what they had to do. Good luck
PS Forum search is your best friend.
Old Dec 22, 2007 | 03:11 PM
Yeah I saw that post and replied to it ... but no response.
Old Dec 22, 2007 | 04:06 PM
So this is the info I have on the Hulk wheel.
17 x 7.5" / 50mm offset
So back spacing on that wheel would only be 2.25" ?? that doesnt seem right ..
Old Dec 22, 2007 | 04:53 PM
fathomgreencamaro's Avatar
No modifications necessary.
Get em!
ID:	4997   Click image for larger version
Old Dec 22, 2007 | 05:06 PM
So is this a different rim .. center looks like it is different.
Old Dec 22, 2007 | 07:12 PM
Yeah, that's a different rim. Not sure what that comes off of.
If it's off of a commander it will fit. Looks good.
Old Dec 22, 2007 | 07:20 PM
Yeah its off of a commander. this is the wheel I want .. again from a commander.
Old Dec 22, 2007 | 09:50 PM
seal20's Avatar
These are not from a Commander, they are from a WJ...
