ok i'm a idot
Old Jun 20, 2012 | 05:50 PM
HIDEOUT's Avatar
Default ok i'm a idot
So I bought a new gas cap cover one with a door. Ok there is 4 tabs that hold in the stock one I can fit my fat hand to release two of the tabs but the other two are one the front side and I can not find a way to release them any sugestion would be appreciated.
Thanks, Gary
Old Jun 20, 2012 | 06:14 PM
Zombie Hunter's Avatar
One of my first mods. Keeps mud/snow/ice off my cap.
I had the same trouble, but for some reason, can't remember how. Sorry.
PS: Never met an idot. WELOME to EARTH
Old Jun 20, 2012 | 06:16 PM
aldaman's Avatar
I am going to assume that you are accessing it thru the opening after removing the tail/brake light assembly. If so see if using a flathead screw driver will help reach that tight spot. Other then that find someone with smaller hands to help. Hope you get it worked out....
Old Jun 20, 2012 | 06:22 PM
TheTerminator's Avatar
Teraflex Tech: Jeep JK Wrangler Fuel Door Install - YouTube
Old Jun 20, 2012 | 06:27 PM
jbvan's Avatar
I had the same problem with installing mine. I ended up releasing the 2 tabs that I could reach through the tail light hole. Next I pushed the rubber gasket down the filler neck. that will give you enough play to get the 2 inside tabs to come loose.
Old Jun 20, 2012 | 06:32 PM
aldaman's Avatar
Nice find, all that is needed after undoing the two closest tabs and popping it out is to pull the assembly towards you...
Old Jun 21, 2012 | 03:03 PM
HIDEOUT's Avatar
Thanks, for the help who would thunk it YOU TUBE you guys rock.
P.S THERE IS ALWAYS ONE SMART ASS IN THE CROWD SO I SPELLED IDIOT WRONG, YA'LL KNEW WHAT I WAS ASKING.....
