Leveling kits
Old Jun 24, 2012 | 07:24 PM
2012 Sahara's Avatar
Default Leveling kits
Hi all, newbie here
Anyone install a leveling kit?
Will it allow 33" tires without any other lift?
Im lov'n my 2012 Sahara Jk , now its time to make my own
Rick
Old Jun 24, 2012 | 07:33 PM
afpilot82's Avatar
JK-Forum Ambassador
You will be fine running 33s. Here's a couple links that will be helpful.
https://www.jk-forum.com/forums/jk-s...s-info-190689/
https://www.jk-forum.com/forums/jk-s...ut-lift-17658/
DKehler's Avatar
Yes, and yes. I have a spacer lift. 2" in front and 1 1/2" in back. 33"'s and no rubbing. Try a search in the show and tell thread for leveling kit or 33"'s.
Old Jun 24, 2012 | 07:45 PM
SBEII's Avatar
I think you will be fine. I'm running the teraflex performance leveling kit and 35" BFGs. I have some rubbing at full flex but 33" should be fine.
Old Jun 25, 2012 | 08:44 AM
Jolly_Green_Giant's Avatar
Don't meant to high jack the thread, but I read that wheel spacers may be needed when running this application with stick wheels... Is that true? I'm interested in running this and just want to make sure. Thanks!
Old Jun 25, 2012 | 08:52 AM
SBEII's Avatar
You will need wheel spacers if you are going to run a wider tire like a 12.50. I'm using Spidertax 1.50".
Old Jun 26, 2012 | 07:10 AM
FRED64's Avatar
Here is mine with Teraflex BB Levelling kit, Grabber AT in 275x70/18 (33x10,5) and 1,25 wheel spacers...
ID:	333965   Click image for larger version
