Track Bar Question-Need Opinions
Looking to purchase front/rear adj. track bars. I was curious if any of you have any experience with the following brands or had any recommendations.
Superlift
Black diamond
Rusty's
They are all in the $130 range. Is the quality OK or is it worth it to go with the more expensive brands like TF or JKS?
Superlift
Black diamond
Rusty's
originally ordered black diamond,showed up as naked bar,no hiem joint or bushing,sent back spent alittle more ordered teraflex,very happy with it,easy to adj.lots of flex and no bump steer with my 3" system and stock draglink/pitman arm,all of my suspension is teraflex,had black diamond front springs too stiff+didn't sit straight
Thanks for the info. I was VERY close to going with the Tera bars, but had a coupon for 4WD.com (forgot about it). So, I went with Full Traction front and rear. $324.00 for both. Never bought anything FT before, so we'll see.
Also ordered the Daystar dash, Pro Comp light bar, Mopar slush (floor) mats and Mopar side step/rails. It was an expensive night for me
I saw the Pro Comp too. I have had 2 Pro Comp lifts in the past on 2 Silverado's and they were great, no problems. I just wasn't too sure about the angle of the Pro Comp track bar. Maybe it's better, who knows, I do know that the Full Traction is gusseted around the end joints and appears beefier. I'll let you know how they work out.
cannot keep teraflex front track arm tight,clearance issues in upper mount under severe flex,gonna tear mount off.changing to rubi express severe duty with drop/reinforce bracket+high steer drag link,also tera flex rear track arm drop bracket,caved in my rear shock under full compression(thank christ just had cheaper shocks on and havent upgraded to resi's yet.gonna change to adj track bar with raised lower mount.no problems with tera flex upper+lower control arms or rest of components though.13 month old vehicle currently reworking 3rd suspension configuration,only in a jeep,it's a damn addiction
What was loose on the front track bar?
Superlift
Black diamond
Rusty's
Superlift
Black diamond
Rusty's
