Rock Krawler 2.5 3.5 question
Old Aug 6, 2012 | 04:57 PM
Fourtango's Avatar
Default Rock Krawler 2.5 3.5 question
I'm trying to decide between these two lifts and my question is do they both have the same control arms?? For the kits that come with all control arms are they the same ones? It would make my decision a lot easier. I already ordered my wheels (atx slots) and tires (km2 35 12.5). I talked myself out of "needing" 37's but if I wanna go higher in the future it would be nice to know all I didn't have to replace the control arms. I have a 2012 JKUR auto
Old Aug 6, 2012 | 05:08 PM
rb1boxer_3's Avatar
I have the 3.5" and the arms are the same for 2.5 i have 37s and it looks perfect. If you get the 2.5 you can still fit 37s just get flat fenders and all you have to do is swap coils if you want to go higher.
Old Aug 6, 2012 | 06:44 PM
Fourtango's Avatar
Cool, that's what I was hoping/planning on doing
Old Aug 6, 2012 | 07:02 PM
tslewisz's Avatar
Believe it or not, the rear arms on 2.5" kits are shorter. I have a 2.5" Max Travel Pro system and was thinking about getting upper rear arms. I have two choices at this point:
- Buy all 4 rear arms for a 3.5" kit.
- Have RK custom make me some upper arms at the proper length.
Later this year, RK will be coming out with a 2.5" X Factor system which will have the uppers included, and they'll be the same as the ones they'll build you custom now.
BTW, a lot of guys buy 3.5" X Factor systems but specify 2.5" springs. That'd be a great way to go, IMO.
cheers, Scott
Old Aug 6, 2012 | 07:20 PM
JKCowBoy's Avatar
The Rock Krawler 2.5 max travel is well designed and easily upgradable. I am running 4" springs and only needed to change the shocks and the sway bar link rods ($7each).
Old Aug 7, 2012 | 01:48 AM
Fourtango's Avatar
cheers, Scott[/QUOTE]
Thanks for the input. I was even thinking of doing that but getting evo 3" plush coils instead.
Old Aug 7, 2012 | 01:51 AM
Fourtango's Avatar
The Rock Krawler 2.5 max travel is well designed and easily upgradable. I am running 4" springs and only needed to change the shocks and the sway bar link rods ($7each).[/QUOTE]
Do you have room for 37's? I like that the 3.5 rear arms push back the axle 1"
Old Aug 7, 2012 | 05:16 AM
tslewisz's Avatar
You weren't asking me, but will say that if you're willing to cut your fenders, 37's fit easily under a 2.5" Max Travel. Here's mine on 35's with only 1" bump stops in front and 2.25" in the rear (I have EVO Rockstars or I wouldn't even use that much).
Old Aug 7, 2012 | 05:45 AM
JKCowBoy's Avatar
Do you have room for 37's? I like that the 3.5 rear arms push back the axle 1"[/QUOTE]
I am running 35s but I know lots of folks who run 37s with no issue on 4" lifts. You will want good bump stops and perhaps trm the fenders.
Old Aug 7, 2012 | 05:47 AM
Fourtango's Avatar
[/QUOTE]
Forgive my "noobness" but what do the rockstars do?? I thought they were just skids for the lower control arm mount. Thanks for all the info and pics fellow jeepers.
