Evo Coilover or Rock Krawler 3.5 X Factor Coliover Long Arm ?
Hi everyone
I am new to the forum (been a diligent reader for a few days) and a new owner of a 2012 Rubicon 2Dr.
For my lift I am considering (a) evo coilovers (b) Rock Krawler 3.5 X Factor Coilover Long Arm
My objective is to do it right the first (and only) time. I want excellent on-road handling. By that I mean nimble and comfortable. Precise steering and not the "floaty" feeling of the stock Wrangler - but not harsh either. Somthing I can drive everyday and drive it to Moab, Colorado, S. Cal or where ever.
I also want it to be extremely capable off-road. I want to be able to go anywhere and handle any trail and feel that the Wrangler helped me overcome my own limitations as a driver.
I also own a Land Rover LR4 and every time I go on a trail and I only see Jeeps there, I know that LR4 wizardry helped me get there with ease - not my driving alone.
I want the same feeling with this Jeep.
I am not sure whether to go 35" or 37" tires.
Between the Evo and RK. I am leaning toward Evo. But - will I also need long arms with the Evo (hence increasing the price tag even more) or can I get the Evo coilovers with stock Rubicon control-arm setup ?
RK kit has coilovers in the front only, but its their top of the line suspension kit and they apparently have a life time warranty on parts.
Another thing is reliability. For the most part I hope this requires minimal up-keep and not constant visits to the installer's shop.
I am going to swap the front and rear drive shafts and I believe some re-positioning of the the exhaust will be needed.
Also - I not doing this myself but a reputable installer in Dallas/Fort Worth area will do this for me.
I would really appreciate some opinions on this. I want to do it right.
What would you pick: Evo or RK or something else ?
Thanks for your time ...
Cheers!
Cheers!
To save you from basically starting another turf war
just read thru this entire thread I have linked for you. It has all the EVO vs RK comparisons throughout it. It has lots of facts and lots of rookie "my friend who knows a guy that saw......" type of back and forth, but bottom line it will spell out who the obvious choice for you is. I know who and why I selected what I run and this thread link should help you my friend!
https://www.jk-forum.com/forums/modi...g-lift-232536/
just read thru this entire thread I have linked for you. It has all the EVO vs RK comparisons throughout it. It has lots of facts and lots of rookie "my friend who knows a guy that saw......" type of back and forth, but bottom line it will spell out who the obvious choice for you is. I know who and why I selected what I run and this thread link should help you my friend! https://www.jk-forum.com/forums/modi...g-lift-232536/
Much appreciated!
I just finished 2 days on the Rubicon trail... My 2012 jku rubicon with 3.5" RK max and 3 guys on Evo coil overs. I didn't get stuck once, had a blast, and saved 2-10k over what they paid. In happy with my lift choice
Was there any point where your Jeep had to work harded than theirs and be assisted ?
Thanks for your time.
Cheers!
I have the rock krawler 3.5 max travel plus kit and love it. I also did the rubicon last month and had no problem at all with a 4 door on 37's. If I had it to do over I would go with the evo high clearance long arms with there coilovers. Both nice kits though.
On the do-over why would you go with evo high clearance long arms?
And why the coilovers?
Cheers!
I have needs and wants, do I need long arms with 3.5 inches of lift, no I don't. Do I need coilovers, no I don't my jeep rides really nice on and off road. But that said the evo high brackets gives you more clearance, which is nice and the long arms will give you a better ride on the road too. The coilovers are longer and will give you more flex.
So (from your signature) you have mid-arm control arms and for a do-over you'd rather go with long arms for even better on-road quality.
Cheers!
