Hub rings
Old Aug 10, 2012 | 06:18 PM
12HTownSahara's Avatar
Default Hub rings
Okay so I'm getting some vibration and I think it's my wheel spacers doing it. I have RC wheel spacers. My question is can I get hub rings to help with this. Do I get hub rings to go from my jeep hubs to the spacer or from the spacer to the stock wheels or both. On my f150 I had some vibrations that went away when I got the hub rings. Just wondering if this may help. I really like the stock wheels and want to keep them.
Old Aug 10, 2012 | 06:24 PM
Oh and the RC spacers are hub centric. What side is hub centric.
Old Aug 10, 2012 | 09:06 PM
JOSH27's Avatar
I have the rough country spacers also and i have no vibrations what so ever. did you notice the vibrations immediately after installing them or has it came up awhile after installing them? Check and see if all the lugs are torqued correctly and maybe even take them off and see if that fixes it? I know the RC spacers are hub centric from the spacers to the hub. I don't remember if they are wheel centric or not. That could also depend on the type of wheel you are running too. I think the factory wheels may not be hub centric without spacers and there are no problems with them like that from the factory.
Old Aug 11, 2012 | 04:30 AM
Yeah I'm going to take them off and check them. I get the vibrations as I'm coming to speed. I'm using the stock wheels and can't run without the spacers.
