Tire sensors
I was able to. But do note that they sensors will probably go off much sooner in cold weather. The margin of confortable ride and having the sensor going off is pretty small. Not sure if they can be adjusted without the dealership conputer
I've had a dealer adjust the threshhold down a few psi to accomodate a different tire. You can also do it yourself with most tuners and programmers.
