Installed 2" Budget boost and now have check engine light
Installed lift and after about 86 miles the check engine light came on, my buddy said it might do that, something about the front end? not sure, can it be cause the steering wheel might be off just a tad? will an alignment fix the problem? Thanks in advance
Not much experience here but I would say 100% it's not on because of an alignment. I would aim more towards the thought of a sensor or something that got bumped while installing the lift.
If it was to be from the alignment goddamn I'd pull the check engine light out! Up here in PA these roads fuck up your alignment 10 feet out of the garage parking lot.
x2 on the coincidence. The only thing I can think off related to the lift would be:
The ABS line
The Brake line
The locker wire if you have a Rubi
If anything happens to those items above the check engine light wouldn't be the one to light up...
The ABS line
The Brake line
Well, must had been a coincidence, took it to the Zone and showed a P0300 which is a cylinder misfire detected- random cylinders, explanation is the powertrain control module monitors the crankshaft speed and has detected a misfire condition...probable cause: ignition system fault-sparkplug(s), igntition wires or coil, vacuum leak, injector fault, high or low fuel pressure. This is covered under warranty correct? Gonna do a random check under the hood, maybe some bad gas? can't take it to the dealership till next week. Thoughts?
It didn't say which cylinder it was, I do know that my MPG 's went from 15 mph to 17.1 in virtually 3 days, I thought that was kinda strange. My question is will this be covered under the warranty?
