Bilstien 5100's with a 3/4" lift?
Old Sep 18, 2012 | 03:25 PM
Halas's Avatar
Default Bilstien 5100's with a 3/4" lift?
Will I be ok if I put Bilstien 5100's on my jeep that has a 3/4" lift on it?
I know this may sound silly but it was the most I could do with still being able to fit in the garage.... The Bilstien shock say 2" lift.... Is this going to cause a problem or are they not going to function as well?
Thanks,
Jeff
Old Sep 18, 2012 | 03:34 PM
chris@offroadevolution's Avatar
Sponsoring Vendor
Thanks,
Jeff
depends on the shock length, you dont want the shock bottoming out.
Old Sep 18, 2012 | 03:44 PM
Halas's Avatar
Rear,
Bilstein 5100 Series Shock Absorber
Collapsed Length (IN): 15.39
Extended Length (IN): 26.38
Travel Length (IN): 10.99
Lower Mount: Eye 12.1mm
Upper Mount: Bar pin
Shaft Diameter: 14mm
Reservoir: No
Finish: Zinc plated
Body Design: 46mm ID smooth body (Non-coilover)
Internal Design: Mono tube
Old Sep 18, 2012 | 03:48 PM
Halas's Avatar
Front:
Part Number: BIL24-146708
Collapsed Length (IN): 14.98
Extended Length (IN): 24.63
Travel Length (IN): 9.65
Upper Mount: Stem
Reservoir: No
Finish: Zinc plated
Old Sep 18, 2012 | 03:49 PM
Halas's Avatar
Will they bottom out?
Old Sep 18, 2012 | 04:25 PM
Freewill's Avatar
Bilstein says that shock is for 1.5 to 3 inches of lift. You might need a 1" bump stop pad on the axles to keep the shocks from bottoming out. Also, they just might extend long enough to let a spring slip out without restraint straps.
Old Sep 18, 2012 | 04:30 PM
Halas's Avatar
Thank you, I may just go with the heavy duty yellow shocks, I really did not like the color of them though...
Any other ideas for quality shocks without breaking the bank?
I could get 4 hd bilstiens and a Bilstien steering stabilizer for $343 shipped no tax.
And if any of you sponsors can match that I would prefer dealing with you on the thread, please send me a PM.
Old Sep 18, 2012 | 07:58 PM
Freewill's Avatar
I didn't actually find them on the Web site, but Bilstein must build a 5100 for the stock suspension height. They should work fine with the 3/4" lift.
Old Sep 19, 2012 | 03:19 AM
Halas's Avatar
They do, they are called 4600's
