spare tire size
It's a good idea for the spare to be the same size.
If you need it to get off the trail you can use a smaller tire but you would want to keep lockers unlocked and use 4wd only when needed otherwise you could hurt your drive train.
If all you care about is getting home, then just slap on any ole size.
Pretty much.
I bought 5 tires to avoid being in this situation. I also do a 5 tire rotation to keep them all close in wear. Not that a brand new 35 of the same make would cause massive amounts of strain on the drive train when being thrown on with tires that have 10k miles on them.
Bottom line, you can't go wrong with a full size spare.
