How To Get The Most Flex???
Old Sep 25, 2012 | 02:55 PM
2012-JKU-Brad's Avatar
Default How To Get The Most Flex???
Im about to buy the 2.5in Tera Flex spring lift w/ bilten 5100 to match. I dont want to get any taller of a lift but I would like to maximize the flex I can get out of the 2.5in's.
so the question is, how to get more flex?
Should I get different sway bar links? Bump-stops? Adjustable control arms? Etc?
Any suggestions would be helpful.
Old Sep 25, 2012 | 02:57 PM
And I will will be running 33-35in tires. I havent decided yet
Old Sep 25, 2012 | 03:33 PM
BigSteve's Avatar
If your lifting 2.5in I hope your going to 35's otherwise there is no real reason to lift for 33's. Why not just cut your stock fenders flat and put 33's on there and see how that works out for you and upgrade as needed? As far as maximizing flex goes i'm not certain I understand the question. Are you trying to get more down travel out of the 2.5in kit?
Old Sep 25, 2012 | 03:49 PM
More down travel is the goal. If that's even possible.
Old Sep 25, 2012 | 06:10 PM
BigSteve's Avatar
I'm with him.
Old Sep 25, 2012 | 06:24 PM
What about quick discos? Should I get them?
Old Sep 25, 2012 | 06:31 PM
JE8154's Avatar
Absolutely, nothing sucks more than trying to disconnect with wrenches under your jeep while everyone else pulls 4 pins and is waiting for you. JKS quicker disconnects the best $150 you will ever spend on your jeep.
Old Sep 25, 2012 | 07:14 PM
JKZinger's Avatar
Pushing a button is even better!
Old Sep 25, 2012 | 07:20 PM
BigSteve's Avatar
I'll see your button and raise you an AntiRock. Ha checkmate!
Old Sep 25, 2012 | 07:43 PM
tnt008's Avatar
Amen brotha, lol
