285 70 r17 bfg ta ko on stock 2013 unlimited rubicon
Not to hijack this thread...but I've been wondering the exact same thing and I'm curious about a follow up question. How different in size are the BFGs in this configuration as compared to the stock SRAs (or BFG MTs)?
I'm not sure I understand the tire ratio piece, and which dimension changes as you go from 255/75 to the size we're talkin here.
The first number is the width of the tire in MM, and the second number is the aspect ratio (sidewall height) - which is the percentage of the width. To get converted into inches, just divide by 25.4 (that is how many MM there are in one inch).
So, a 255/75/17 should be right around 32x10 (255 divided by 25.4 is basically 10" , which is the width - 75% of 10" is 7.5", which is the sidewall hieght - 7.5" x 2 is 15" of total sidewall - plus the 17" rim equals a total hieght of 32". Confusing yet?
Soooo, a 255/75/17 is 32x10, and a 285/70/17 is 32.7x11.2 - within reason.
It is a little confusing by nature...but you really cleared up the math. Thanks for that!
The only part I don't get is how a 10" wide tire and an 11.2" wide tire fit on the same width stock rim. I guess the bead is in the same spot, but the profile flares out further at the treads?
Here is my Jeep with Stock 17" wheels and 285/70/17 BFG A/T KO tires.
Granted, I do have Rough Country's 1.5" spacers. Had them since i had the stock SRA tires on it.
You do not need a tire carrier for this small of a tire.
