2012 exhaust question
Old Sep 26, 2012 | 06:52 PM
alanscott1's Avatar
Default 2012 exhaust question
Does anyone know if the dynomax evo comp system part#39522 will fit on a 2dr? I can't seem to find a definitive answer to this. I'm ideally looking for something that dumps before the axle, after having to move my swaybar back about 3-4" to clear my coilovers I don't have much room for a muffler back there. I saw that magnaflow has similar kit out (part#17144) just cant seem to find much info on it. Any suggestions are appreciated.
Old Sep 26, 2012 | 07:05 PM
Dynomax's Avatar
Sponsoring Manufacturer
It is not a "bolt in" per se.
It would require some cutting on the extension pipe to make it work.
Old Sep 26, 2012 | 07:13 PM
alanscott1's Avatar
Thanks for the quick reply! How much would I have to hack off you think? Also is the extension pipe flared on both ends?
Old Sep 26, 2012 | 07:19 PM
Dynomax's Avatar
A three month old makes for weird business hours.
I am not too sure on how much needs to be hacked off.
Check out (if you want) on our Facebook page, there is an album called "2012 Evo Comp Install" or along that lines.
Also WOL did a write up as well, but they have a 4 door.
I have only done an install on a 4 door. What needs to be done is to get the rear "dump" to attach to its point on the EVAP canister.
Only flared on one side as well.
Old Sep 26, 2012 | 07:25 PM
alanscott1's Avatar
WOL's video is what sold me on the system, read his write up a few times as well. I'll look for your install photos as well. Doesn't sound like it will be all that difficult to make it fit.
Old Sep 26, 2012 | 07:32 PM
Dynomax's Avatar
Measure 3 times and cut once.
Oh yeah... it may be (most likely) on back order. I am hearing a couple of weeks out....
Old Sep 27, 2012 | 02:18 PM
alanscott1's Avatar
Yeah after seeing it was on back order I ended up ordering part# 39524. Got a heck of a deal through 4wd.com that I couldn't pass up!
Old Sep 27, 2012 | 02:24 PM
Dynomax's Avatar
Very cool!
