275/65R18 Duratracs on 18" sahara wheel
Old Oct 5, 2012 | 01:59 PM
AirJordan613's Avatar
Default 275/65R18 Duratracs on 18" sahara wheel
Would this tire fit on my stock sahara? According to the specs it shouldn't be any taller then stock but will be a little wider. 32.1" overall diameter on 8" measured rim, rim width range 7.5" to 9". Tread width 9". Thanks.
Old Oct 5, 2012 | 02:03 PM
Flip94ta's Avatar
The wheels are 18X7.5 so it's within GY's specs. I'd love to see some pics since I've considered this size too.
Old Oct 5, 2012 | 03:40 PM
Tripletsi's Avatar
Subscribed for pictures.
Old Oct 5, 2012 | 04:56 PM
Ryan0260's Avatar
Yes they will fit. Those wheels are 7.5" wide. I run 35x12.50's on the same wheels and they are fine
Old Oct 5, 2012 | 05:26 PM
blue project's Avatar
I do have a leveling kit on the jeep in this pic but yes they will fit. About stock height just a little wider. No rubbing, no issues!
Old Oct 5, 2012 | 06:10 PM
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=374624"/>
Do you think they will be good without the leveling kit?
Old Oct 5, 2012 | 06:21 PM
Cordur's Avatar
I have those on mine. You need spacers to fit them at full turn or they will rub on the sway bar. Not a bit deal if they do but just keep in mind that they will. Mine only rubbed on the drivers side on a full right turn.
Old Oct 5, 2012 | 07:18 PM
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=374649"/>
Do you think it's worth it? I'm looking to replace my stock tires but I see a lot of snow in Cleveland.
Old Oct 5, 2012 | 09:34 PM
You should be fine. The kit only give a few inches of height at best. I never had any rubbing ever. There are plenty of people running bigger without issues.
Old Oct 6, 2012 | 06:24 AM
Cordur's Avatar
They are a pretty great tire in the snow and on icey roads. We get a fair bit of both in Alberta. They seem to grab nicely on rocks and I'd say they are fair in mud. Not going to be a replacement for a true mud tire, but I think they are about as good as it gets for doing everything really well.
One thing I'm waiting on now is a procal so that I can lower my sensor settings. Should have done this right from the get go. You'll want to run them at a lower pressure than the stock tires and if you'll find the sensors will sometimes come on even at say 32 psi and of course at 15 psi on the trails.
