2.5" Lift w/ 35s: will it fit = of course; Will it PERFORM = ???
Old Oct 11, 2012 | 03:23 PM
dave nelson's Avatar
Default 2.5" Lift w/ 35s: will it fit = of course; Will it PERFORM = ???
Running an AEV 2.5" XT lift with Treadwright 285/70R17 (~33's). Loving the handling on/off road, as well as the extra flex I'm getting over the stock setup.
I'm mulling over the idea of throwing on some 35's, and as the forums are full of "will it fit" / "will it rub" questions, it's obvious that fitment is not an issue, especially seeing that some guys are even getting away with 37's on such a small lift (with some trimming).
What I'd like to know instead is, will it PERFORM. I.E. Would you expect for flex to be impeded in any way by maxing out the tire size for the lift? Is there any reason offroad/crawling performance-wise that I'd want to stick with 33's given only a 2.5" lift?
My thought is that the bumpstops will hit the same (no rub), and that downward travel will technically be greater by 1" due to extra tire diameter. Add that to more rubber on the ground, and you've got overall better performance (plus it'll look cool)
Old Oct 11, 2012 | 04:06 PM
bryan302's Avatar
I have treadwright 35s the wardens. They are horrible. I cant get over 100kmh without my jeep shaking apart. ive gotten them ballenced twice. How have yours been for you
Old Oct 11, 2012 | 04:26 PM
Edge Hawk's Avatar
What gears do you have?
Old Oct 11, 2012 | 04:29 PM
project06tj's Avatar
RK 2.5 and 35s. Make the decision yourself...
ID:	377063   Click image for larger version
ID:	377064   Click image for larger version
Old Oct 11, 2012 | 04:33 PM
My 33s are the wardens. The 35s they're making right now are the Guard Dogs. I have had zero issues with the wardens at all, but the A/T pattern was definitely a compromise (would go M/T hands down for the 35s).
Old Oct 11, 2012 | 04:35 PM
4.10s right now, but I'll be throwing in new gears, and sleeves/gussets before making the tire move.
Awesome flex! You're just using the RK kit, no other changes?
Old Oct 11, 2012 | 04:46 PM
ski-YA-later's Avatar
Do it 35s look small now. I would be upset with 33s
ID:	377071   Click image for larger version
Old Oct 11, 2012 | 04:47 PM
Sleeved and gusseted, RK Flex w/ Bilstein 5100s and 2" bump stops. On road ride is great. For the money I could not be happier with how it performs Offroad.
Old Oct 11, 2012 | 05:26 PM
TheTerminator's Avatar
Yes, of course it will perform. Just keep in mind, depending on axle centering, wheel backspace, tire width, you will likely have to trim your fenders. It will rub to the point of tearing fenders from the body, if you don't. My right rear fender was partially torn off just after a few flexes. After I trimmed them, it still rubs a bit on the inner plastics in the rear, and maybe even the stock rear bumper - it is awfully tight.
