Adjustable driver seat
Old Nov 4, 2012 | 10:56 AM
Rizzo22's Avatar
Default Adjustable driver seat
Hey Guys! Names Reece and I'm new to the jk world! So my problem is that I have my driver seat adjusted to max height and every time I get in I have to readjust it. Is it just mine or does anyone else's do this? I drive a 07 unlimited rubi.
Old Nov 4, 2012 | 10:59 AM
Explorebc4x4's Avatar
I have a 2012 JKU sport and have the same problem.
Old Nov 4, 2012 | 11:48 AM
Rizzo22's Avatar
Thanks, glad to know I'm not the only one. I wonder if there's a way to fix it?
Old Nov 5, 2012 | 08:03 AM
kh202's Avatar
I could be wrong but I think it's just cuz when you get out and put your weight on the edge of the seat, it pushes down on the lever and lowers it a bit. Same when you get in. Open your door and push on the edge of the fabric and see what I mean. Could be wrong but I think that's the culprit...
Old Nov 5, 2012 | 11:16 AM
Cowboy5150's Avatar
I looked into that on Saturday and it looks as though you can pull off the handle and move it.
Old Nov 5, 2012 | 11:32 AM
Rizzo22's Avatar
How do you mean?
Old Nov 5, 2012 | 11:58 AM
TriJeepV's Avatar
Had the same issue and found someone on here that had moved his so I did the same thing. You will need to move both levers to make it work. Works perfect now, haven't had to adjust since the move.
After:
Old Nov 5, 2012 | 12:35 PM
Delux2769's Avatar
I did the same as TriJeep, but angled my big lever straight down.
Old Nov 5, 2012 | 12:41 PM
Rizzo22's Avatar
After:
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=385659"/>
How do you get the levers off? Just pull?
Old Nov 5, 2012 | 01:13 PM
Delux2769's Avatar
Pop the center cap off carefully.
Then use a T45 (i think) to unscrew it. Spin it and you'll feel it pop down into it's slots in the back.
