Lift and stock wheels
Old Nov 8, 2012 | 03:26 PM
Guinness79's Avatar
Default Lift and stock wheels
I need some help. I installed a 2.5 in teraflex lift on my 2009 4 dr this summer. I want to put my factory 18in wheels back on for the winter. can i install a shorter rear swaybar links so it wont rub? I really dont want to get wheel spacers.
thanks for the help.
Old Nov 8, 2012 | 09:53 PM
deaner23's Avatar
I'm not sure after the shorter sway bar links but I have a 2.5 inch lift and without the spacers my 35's rubbed bad at full turn. The whole jeep would shake bc of it and now that I run spacers they've been driving amazing for the last year. Hope that helps somewhat
Old Nov 8, 2012 | 09:56 PM
Delux2769's Avatar
I would suggest you buy a set of Rough Country 1.5" spacers. They only cost $118 shipped to your door and you can run your lift with the 18" stock wheels.
Otherwise, you cannot run the stock wheels and lift. Shorter sway bar links will put your rear end in a bind and can cause major trouble.
