broken exhaust manifold bolt
so the jeep has (2) broken exhaust manifold bolts. Does anyone know if ARP makes replacement bolts? If so a part number would be great! Last thing I need to do is put another factory bolt in and have it break again!
OEM is listed as:
Part # 06507938AA
BOLT, M8x1.25x30, Exhaust
Manifold To Cylinder Head,
Mounting
Here are ARP part numbers M8 x 1.25 x 30 bolts (5 per pack): Black Oxide Hex 661-1003 / Black Oxide 12 point 671-1003 / Stainless Hex 761-1003 / Stainless 12 point 771-1003
Part # 06507938AA
Mounting
Thanks, now to decide what flavor of bolt to use when I get around to fixing the broken bolts this spring. I want to believe the ARP bolts will hold up better then the factory stuff?
