Front axle ujoint seized
Old Dec 12, 2012 | 11:05 AM
jeepwave's Avatar
Default Front axle ujoint seized
Hey guys just wondering how common this is. I am regearing today and I just got a call from the shop saying my front axle u joint was seized...
I drive a 09jku 6 speed with only 50,000km
3.5" aev lift with 35" mtz
This seems like low km? Common for the jk?
We are replacing with some greasable ones
Old Dec 12, 2012 | 11:17 AM
ronjenx's Avatar
It's common, but not because it a JK.
Regular u-joints will seize if water gets into the bearings. Being non grease-able promotes seizure.
I've had it happen to all my vehicles that had regular non-grease-able u-joints on them.
Old Dec 12, 2012 | 11:45 AM
Billnsandi's Avatar
I replaced the ball joint in my Jk rubi several years ago, and discovered one of the axle ujoints was seized and I couldn't move it by hand at all. That was at about 50k miles. We are bone dry here and the jeep has never touched water.
Old Dec 12, 2012 | 11:50 AM
ronjenx's Avatar
Still, moisture gets trapped in there and corrodes the steel. I can't think of anything else that would make it seize.
Old Dec 12, 2012 | 01:14 PM
jeepwave's Avatar
Good to kno thanks this makes sense
Old Dec 12, 2012 | 02:05 PM
mkjeep's Avatar
If you have non greaseable u joints it a good idea to change them out at least every 2 yrs, more often if you wheel in mud and water.
Old Dec 12, 2012 | 02:16 PM
Duh's Avatar
Duh
I broke a vice in half trying to get out a rusted cap on my old xj. Gave up and left it. I figured if the vice broke, that joint wasnt going to. Or if it did, it might be easier getting that cap out then. I suppose i could have tried my hyd press at work though... Too lazy i suppose.
